July 16, 2020, 12:38 |
Interface problem
Aran
I am doing a project on developing a Wankel compressor. I have written a UDF code for the eccentric motion of the rotor and another one for the housing to enable the nodes of the housing wall to move in sync with the speed of the rotor apexes.
The geometry was created in solidworks and the ports are circular extrusions that were not merged with the main body so that they can be kept as seperate bodies. In my mesh I have defined the contact region between the ports and the housing. When I run the simulation, I get an error saying "negative volume cell volume detected" and "Warning: Failed to correct face handedness ". When I previewed the mesh motion at the time step it failed, the face of the outlet port that was defined in the contact region with the housing was moving when it should be stationary. I have not given it a mesh motion and am not sure what to do. I have attached a picture link below. https://imgur.com/dvbSZ1K Please advice. |
July 17, 2020, 02:28 |
Alexander
Rep Power: 34 |
why don't you want to make all geometry as one part, without contacts?
best regards ****************************** press LIKE if this message was helpful |
December 30, 2021, 03:31 |
İstanbul
Rep Power: 4 |
This is necessary because the small apex clearances require the fine mesh density, but the rest of the Wankel expander does not. If the entire mesh density were as fine as the apex clearances, the computational time would be unfeasibly large.
dynamic mesh zones, mesh interface rotating, port flow |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Problem with porous flow at multi-material interface with large permeability diff. | Hisham | OpenFOAM Programming & Development | 1 | June 3, 2016 10:51 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
