Sudden decrease of simulation speed in ANSYS Fluent as the case runs
Old   July 15, 2020, 09:33
Default Sudden decrease of simulation speed in ANSYS Fluent as the case runs
Henry
haiteng is on a distinguished road
Hello! I am implementing a two-dimensional URANS simulation with a mesh size of ~150k and a time step size of 0.01 s. The case is run on 16 CPU cores with single precision. In the beginning of the simulation, the case runs quite fast, and 1 s physical time (100 time steps) only takes an elapsed time of 11 min. However, as the calculation proceeds, the simulation speed decreases greatly. Now, it takes an elapsed time of 70 min for 1 s physical time! I haven't changed anything on the case. It is just there and keeps running. Could anyone give me hand out of this?
Here are two guesses from me which needs substantiation from professionals:
1. "Data Sampling for Time Statistics" is turned on, will this slow down computational speed as time evolves?
2. After each iteration, CPU usage drops sharply to 8% and then rises to 50% (which is 16 CPU on my computer) when the next iteration is calculated. This phenomenon repeats for each iteration (shown in the figure). Why does this occur? Will this hamper the simulation speed?
Many thanks!
haiteng is offline   Reply With Quote
Old   July 15, 2020, 09:37
Henry
Figure mentioned in last post is attached here. Many thanks!
parallel computing
Downdraft Gasification simulation in ansys fluent Muhammad Waleed FLUENT 1 April 25, 2021 04:55
How to run multiple cycle pulsetile flow simulation in Ansys fluent using UDF code? Md Al Amin Sheikh Fluent UDF and Scheme Programming 4 January 28, 2020 12:55
Fused Deposition Modeling Process Simulation in Ansys Fluent ttp262 FLUENT 0 October 2, 2018 17:07
Reading ansys fluent case and data with fluent 6.3 artemiss1984 FLUENT 1 November 17, 2017 12:11
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
