July 15, 2020, 03:03 |
Species at the interface
Rep Power: 8 |
Hello everyone,
I have 2 phase flow which are a solution and humid-air. I want to define the humidity of water vapor in air at the interface. I know that I should use Define_Adjust(see the following code) but How can I access to only water vapor of humid-air at the interface? The following code pass through the whole domain and cells (even solution side(first species)) but I want to only define water vapor at the interface? DEFINE_ADJUST(adjust_gradient,domain) { int phase_domain_index; real T1, W; Thread *t; cell_t c; Domain *subdomain; sub_domain_loop(subdomain, domain, phase_domain_index) { if (DOMAIN_ID(subdomain) == 2){ thread_loop_c (t,subdomain) { begin_c_loop(c,t) { if(C_VOF(c,t)!=0. && C_VOF(c,t)!=1.){ T1 = C_T(c,t); W = (3.56087706576757E-13*pow(T1,6))+(-6.49782616920242000000E-10*pow(T1,5))+(4.95600960068920000000E-07*pow(T1,4))+(-2.02032299336406000000E-04*pow(T1,3))+(4.63901242081371000000E-02*pow(T1,2))+(-5.68550924813065000000E+00*T1)+2.90434594274724000 000E+02; C_YI(c,t,0)= W; C_UDMI(c,t,0) = W;} } end_c_loop(c,t) } } } } |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Problem with porous flow at multi-material interface with large permeability diff. | Hisham | OpenFOAM Programming & Development | 1 | June 3, 2016 11:51 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 18:15 |
