How to define inlet velocity in 45 degrees from the inlet ? |
July 14, 2020, 12:46 |
Kaboka
Rep Power: 7 |
I would like to define a velocity inlet in 45-degree angle for my quenching multiphase flow (water and air) case in 2D. I have tried to give the axial and radial velocity to inbuilt system, however it does not give me the exact solution. Could anyone help me about it? Do I have to add a UDF file or is there any other tricks you could recommend? Following pictures are my actual case and the velocity vector that I want: https://imgur.com/bSpbkGc https://imgur.com/ixaruoy Thanks in advance Bora |
July 16, 2020, 15:28 |
Guven Nergiz
Rep Power: 6 |
Hi Bora,
I am not sure but; First of all, you need to divide the inlet section into two parts (from middle ofc). Then define the direction vectors and speed inputs one by one. Like in the screenshot below (in this coordinate system your velocity vectors can be X=1/Y=1/Z=0 and X=-1/Y=1/Z=0). I hope that this can be a solution of your problem. Best regards, Güven |
July 20, 2020, 07:50 |
#3 | |
Kaboka
Rep Power: 7 |
Thanks for your answer, as my case is a 2D axisymmetric I don't have a coordinate system section in velocity window. I need an conical velocity profile which has a 45 degrees angles. I tried the following method but it doesn't give me a good solution. I'd be appreciated if you have any idea about that situation. Bests. Bora |
July 21, 2020, 02:40 |
Alexander
Rep Power: 34 |
axial^2 radial^2 component together should give you 1
also you can use other reference frame, not absolute
best regards ****************************** press LIKE if this message was helpful |
July 22, 2020, 08:13 |
Kaboka
Rep Power: 7 |
Hi AlexanderZ,
Thanks for your advice but that didn't work. However, I found a way to define both axial and radial velocity with a Udf code individually. In Fluent, velocity vectors look good as you can see in the attachments, but when I load results to the CFD_Post it does not give the good conical spray nozzle shape. Do you have any idea what is the reason of this problem? Bests, Bora |
July 22, 2020, 08:54 |
#6 | |
Guven Nergiz
Rep Power: 6 |
Glad to hear you solved your main problem. Maybe you should run your case a bit longer to get fully developed region? Best regards, Güven |
August 5, 2020, 15:38 |
#7 | |
Kaboka
Rep Power: 7 |
Unfortunatelly I have tried that as well but that was not the case. I am still trying to find the best solution here. If anyone have any idea about that I'd be very appreciated. In order to make it clear I add one more volume fraction picture on CFD-Post and what I want it really. Thanks in advance. Bests, Bora |
ansys, axial, cfd, fluent, radial velocity |
UDF Velocity profile at inlet | aar007 | Fluent UDF and Scheme Programming | 1 | June 28, 2020 23:43 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
3-D parabolic velocity Inlet - Steady state - UDF Turbulent Flow | mohibanwar | Fluent UDF and Scheme Programming | 10 | May 18, 2015 11:34 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 19:42 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 03:13 |
