Circulation Bubble Behind the Diffuser, Normal?
Old   July 13, 2020, 11:59
Default Circulation Bubble Behind the Diffuser, Normal?
elochana is on a distinguished road
Dear collegues,
Bascially it's a short tube which has a fan blowing in from one end and an HVAC diffuser fitted at the other end (There is a little obstacle inside the tube around which the air flows. But you can forget about it for the moment). A huge re-circulation bubble is generated just below the diffuser and the flow is sucked back into it rather than getting diverged as expected. Is this normal. I can understand the existance of the re-circulation bubble, but a normal diffuser should diverge the air flow, but it seems this is not the case. Pls. help.
Details of the simulation:
Ansys fluent
Models: k-epsilon realizable with default values (k-epsilon standard was also used with similar results on the above issue)
BCs: Fan outlet (exhaust into the tube) -> velocity inlet
Fan inlet -> Pressure outlet. ('Fan-intake' BC was also used with similar results on the above issue)
Thank you
elochana is offline   Reply With Quote
ansys, fluent
[snappyHexMesh] Invalid Normals for source face to target face while making AMI? Sorabh OpenFOAM Meshing & Mesh Conversion 1 August 3, 2021 07:35
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 08:49
Need help setting up chtMultiRegion OskarT OpenFOAM Pre-Processing 1 September 25, 2019 16:51
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
