What is the best way to trip a boundary layer in ANSYS Fluent?
Old   July 8, 2020, 19:41
Default What is the best way to trip a boundary layer in ANSYS Fluent?
Peter Shi
PeterShi is on a distinguished road
Dear Fluent users,
As far as I know, there are two ways to trip a BL in Fluent:
(1) If RANS or DES is used, you can split the entire domain into two sub-domains, one is laminar, the other is turbulent. For the laminar domain, you can check "laminar zone" under the Cell Zone Conditions ta.
(2) You can implement geometry perturbations at the location where a boundary layer is tripped. However, it is the last resolution to me because I really do not want to change the geometry.
A problem comes when I use LES: the laminar zone option is disabled when LES is used. I wonder is there a better way to trip boundary layers in this situation except for the second approach? FYI, I can numerically trip boundary layers easily in OpenFOAM. Not sure if it is feasible in Fluent though.
Best regards,
Peter
PeterShi is offline   Reply With Quote
boundary layer, fluent, tripping
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh crizpi21 OpenFOAM Meshing & Mesh Conversion 5 October 16, 2021 11:56
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
