July 7, 2020, 08:35 |
DPM surface injection cylinder
Danny
I am using Ansys FLUENT 2020 R1. My question is about the use of a 'surface' injection type for a discrete phase (DPM). For my simulation, I want to introduce droplets at the curved surface of a cylinder. To this end, I created a new injection and selected the 'surface' injection type under 'set injection properties'. Using these settings, I want to introduce droplets at the selected surface and give these droplets both a normal and a tangential velocity component. Unfortunately, I cannot find the option to switch to a cylindrical coordinate system (which is possible for an inlet boundary condition). In addition, if I select the 'inject using face normal direction' checkbox, I cannot specify a tangential velocity component. My question is whether someone knows a solution to my problem? At the moment, I can only directly specify X-, Y- and Z-Velocity components. However, in my case these velocity components should depend on the position due to the curved surface. Ideally, I want to simply define the velocity components in cylindrical coordinates. As an alternative, it might be possible to use a user defined function which sets the X-, Y- and Z-Velocity components at the proper locations on the surface (but I do not know how to do this and whether it is possible). I see the latter option only as a last resort. Best regards, Dny |
October 7, 2022, 16:35 |
Nidhi
Rep Power: 9 |
Hi, I am looking to do something similar where I need to specify the velocity of the particle injections in cylindrical coordinates but am unable to find a way to do this. Did you find a solution for this?
cylindrical coordinates, dpm, surface injection |
How to implement time-varying boundary conditions in an enclosed cylinder | Alejandro-FA | OpenFOAM Pre-Processing | 0 | May 14, 2020 06:29 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
enGrid right tool for surface mesh -> cylinder? | mankoff | enGrid | 1 | February 24, 2013 15:54 |
DPM Injection Parameters | Hendawi | FLUENT | 0 | June 13, 2002 09:41 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
