total heat transfer rate and total sensible heat transfer rate
Old   July 3, 2020, 05:50
Default total heat transfer rate and total sensible heat transfer rate
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I am modeling a combustion flow with fluent. All the residuals are flat and below some critical values and monitored variables are constant as well.
I tried to check the flux balance of the whole system. I seclected whole boundaries in the model. The mass flow rate is balanced. However, the total heat transfer rate is -26.81818W and the total sensible heat transfer rate is -2.025117W. I know that sensible heat transfer rate does not account for chemical reaction heat. However, I just reported net results, which means chemical reaction heat is included. Therefore, these two values should be the same and they should be both very close to 0.
I am wondering why they are different? How can I make these values close to 0 when modeling complicated combustion flow?
Best regards
Weiqiang
Weiqiang Liu is offline   Reply With Quote
convergence, reaction flow, sensible heat transfer, total heat transfer
Problem with total heat transfer rate aswathy_raghu FLUENT 9 April 21, 2022 11:36
total heat transfer rate and total sensible heat transfer rate Weiqiang Liu FLUENT 5 June 5, 2020 21:59
Problem with total heat transfer rate aswathy_raghu FLUENT 0 July 26, 2016 08:39
Total Heat Transfer Rate & Total Surface Heat Flux Mismatch icaro FLUENT 0 November 24, 2009 08:01
Inconsistent Total Heat Transfer Rate Ken Adams FLUENT 0 July 24, 2007 12:04
