Orient Profile command for Fluent18.2
Old   July 1, 2020, 02:56
Default Orient Profile command for Fluent18.2
dengdeng is on a distinguished road
I'm now using command lines to build a fluent case with Fluent 18.2. With TUI, if I want to orient the profile, I can simply click Cell Zone Conditions→Profiles→Orient,and everything will be done (this is true for both ver 18.2 and ver 2019R). However, this time I have to use command lines to realize this function. In Fluent 2019R, the command line is easy to find, after reading a profile, input define/profiles/orient-profile in Console and you can translate or rotate the profile. But in Fluent 18.2, there's no orient options in define/profiles. I'm confused and could not get help from ANSYS Fluent Text Command List. Does anyone know anything about this problem?
Thanks for any reply!
The reason why I use command lines insteady of TUI is indicated in this thread:
Fluent reads a large csv profile (over 2G)
Since the size of profile is too large, Fluent seems not able to read it locally with my PC, thus I have to use a Supercomputer and the Fluent version installed in the Supercomputer is Fluent 18.2.
dengdeng is offline   Reply With Quote
Old   August 20, 2020, 23:34
Since the problem is still unsolved, I reviewed my thread and find out that I have made a mistake. I would like to orient the profile through 'TUI', and the 'TUI' above is actually 'GUI'.
command, csv, fluent, profile
SU2 inlet profile error dwstevens SU2 1 June 8, 2020 17:08
OpenFoam restarting simulation, stops at first Time loop syntex OpenFOAM Running, Solving & CFD 4 April 5, 2019 12:20
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 07:25
atmBoundaryLayerInletVelocity - Velocity Profile not continuous through domain sdfij6354 OpenFOAM Running, Solving & CFD 3 July 26, 2017 17:16
Boundary Profile E61 FLUENT 0 January 5, 2011 09:13
