Volume flow rate input
Old   June 30, 2020, 13:30
Default Volume flow rate input
Sathisha GH
smaugtheterrible is on a distinguished road
Hi guys,
I'm new to ansys fluent. I am currently simulating a model where pressurized water (about 40 psi) goes into a pipe and comes out of 5 smaller outlets at atmospheric pressure.
I know the volume flow rate of water going into the pipe. I want to find out the volume flow rate of water coming out.
This is the general setup of my model
Model: SST k-omega
Material: water (liquid)
Boundary condition: Inlet: pressure inlet, inlet pressure 40 psi, intensity and hydraulic diameter
Outlets: pressure outlet,backflow ref frame (absolute), backflow direction specification method (normal to boundary), backflow pressure specification (total pressure), turbulence intensity and hydraulic diameter
How can I calculate the total volume flow rate out of the outlets? Is this setup good enough or is there a better setup?
Is there a way to input inlet volume flow rate in ansys fluent?
I understand that adding picture would help, but I can't do that due to intellectual property concerns
smaugtheterrible is offline   Reply With Quote
How to plot volume flow rate of inlet and outlet in fluent? RueyTeh FLUENT 5 May 12, 2017 21:37
Rainfall modeling using source volume flow rate max0014 FLOW-3D 1 November 24, 2016 04:49
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Volume of Flow Rate (VFR) boundary condition therockyy FLOW-3D 0 May 23, 2011 15:19
