June 30, 2020, 05:25 |
Porous media coefficients and working fluid
Rep Power: 10 |
Hi all,
I hope you all are doing well! I am wondering if the porous media coefficients will change if the working fluid changes. I have a tubular, U-shaped heat exchanger geometry where the working fluid is air. This model has been tested (experiments) in detail earlier, and its porous media coefficients have been estimated. Now I need to use the same heat exchanger geometry (for CFD), but the working fluid is replaced with water. Can I use the above porous coefficients for water? Kindly make your replies. Thanks in advance. Last edited by Dronzer; June 30, 2020 at 05:26. Reason: spelling mistakes |
June 30, 2020, 22:23 |
Please suggest something!
Rep Power: 10 |
Hi all,
Please, if anyone has experience related to the above, kindly suggest something. Sorry, but I am running out of time. |
cfd analysis, fluent 14.5, heat exchanger, porous media model |
heat transfer in porous media | Miko | Siemens | 10 | February 16, 2022 07:13 |
do permeability and inertia loss coefficients values depend on working fluid? | sh.a.ghafour | FLUENT | 4 | July 5, 2020 22:38 |
Defining two different heat transfer coefficients for porous media model | student_1994 | Fluent UDF and Scheme Programming | 1 | May 2, 2019 00:25 |
Interface between Fluid and Homogeneous Porous Media | guilbemloco | FLUENT | 0 | June 11, 2015 09:18 |
Porous Media | Christian Cordeiro | CFX | 2 | January 16, 2004 18:57 |
