residuals and results oscillating during some iteration interval
Old   June 29, 2020, 00:28
Default residuals and results oscillating during some iteration interval
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I am simulating a propane catalytic combustion with user-defined one step gas phase and surface reaction with fluent. it's a steady state case. after iteration started, temperature just proceeded to goal value normally. When it was close to goal temperature, all residuals suddenly started to oscillate and so did the temperature results. If I decrease URF of energy, the oscillation would be postponed after tens thousand of iterations. However, it still occured.
I tried to turn off surface reaction with gas phase reaction only since I am pretty sure about the correctness of gas phase reaction. Then the case can be converged very well. I defined the surface reaction following literature. Because there is no nomenclature in the paper. I can't know the units in those equations. I just did some unit transformation.
I am wondering why would this happen. Is something wrong with my surface reaction scheme?
Ps: I am using non-explicit source chemistry solver. If I use stiff chemistry solver, oscillation would occur along the whole iteration process.
Best regards
Weiqiang
Weiqiang Liu is offline   Reply With Quote
Old   October 5, 2020, 04:52
SAM
hnemati is on a distinguished road
How you found the solution of your problem? I have the same issue.
hnemati is offline   Reply With Quote
gas reaction, oscillating, residuals, surface reaction, user-defined
how to avoid residuals oscillating? Weiqiang Liu FLUENT 8 June 2, 2020 12:53
unchanged residuals and changing results Weiqiang Liu FLUENT 2 February 17, 2019 13:17
Solution not converging, but oscillating residuals around a constant value Irene FLUENT 2 February 7, 2012 12:55
Oscillations in Results and Residuals Freeman FLUENT 27 December 18, 2010 14:09
A basic doubt on reading the iteration results hariya03 OpenFOAM Post-Processing 0 July 16, 2008 09:28
