Different results when I use parallel computing |
June 26, 2020, 17:50 |
Rep Power: 6 |
I am trying to solve a simple combustion problem with Fluent. However, the result of the mass fraction for specific gas when the Solver Processes parameter is 1 is significantly different from the case when I change it to 16. Do you have any idea where this difference is coming from and how I can fix it? Thanks |
June 26, 2020, 18:22 |
Lucky
Rep Power: 66 |
Any convergence or stability issues?
June 26, 2020, 18:29 |
Rep Power: 6 |
Yes, I understand. It seems I didn't describe the problem very well.
I am just changing the number of the processors to 16, and as a result, the mass fraction at the end of the time step in my goal location is significantly different from the case I have just 1 processor! Thanks |
June 26, 2020, 18:31 |
Rep Power: 6 |
No issue at all. It's working very well in both cases. However, the results are different.
combustion, fluent, parallel calculation, species mixing |
Running in parallel produces incorrect results and odd residuals | jtipton2 | OpenFOAM Running, Solving & CFD | 4 | March 6, 2020 23:34 |
Wrong results in OpenFoam parallel runs | visakhmg | OpenFOAM Running, Solving & CFD | 1 | November 9, 2013 13:13 |
Error with parallel computing: MPI | therandomestname | FLUENT | 1 | June 28, 2012 04:12 |
Diffusion equation solved using Parallel Computing | Sachin Paramane | Main CFD Forum | 0 | June 11, 2007 23:48 |
Parallel Computing on Multi-Core Processors | Upgrading Hardware | CFX | 6 | June 7, 2007 15:54 |
