June 26, 2020, 07:45 |
Fan Simulation Problem
Mehmet
Rep Power: 7 |
Hello guys,
I have a problem about fan simulation with MRF-frame motion at steady state on fluent. I want to compare the techical data and CFD results. The power of the fan motor is 250 Watt and there is to be some power loss due to mechanical components, electricity tranforming and heat. The revolution per miute of the fan is 1380 rpm. I analyzed the fan in fluent. From the results, I have read the mass flow rate, pressure change by reading the total pressure at the fan inlet area and at the fan outlet area. Finally, I have calculated the power with Power=mdotxDeltaPressure and obtained about 50 Watt. This calculated power seems very low when compared to thecnical data. The velocity vector on a plane at the middle zone of fan is at the attachments and there are some reverse flow. It seems very strange to me. Are there any problem that you notice? Please inform me. |
June 26, 2020, 07:47 |
Mehmet
Rep Power: 7 |
Actually I want to obtaine the power carried to the air. I suppose it should be 110 Watt but I calculated 50 Watt.
June 26, 2020, 09:27 |
André
Rep Power: 10 |
Power should be volume flow x dP, not mass flow
Sapere aude! |
June 29, 2020, 04:19 |
Mehmet
Rep Power: 7 |
Empty object Meshing and Fan boundary condition | cfd_user_pune | FloEFD, FloWorks & FloTHERM | 9 | May 29, 2024 15:35 |
Simulation of a flow of air in a room from a fan | tejas_jeurkar | FLUENT | 0 | April 4, 2019 12:41 |
Problem with FsiFOAM simulation of beams (2-4 beams) in a steady simple shear flow | Aliiiii | OpenFOAM Running, Solving & CFD | 1 | February 27, 2019 13:26 |
Simulation and Optimisation of centrifugal fan 3D to 2D | eRzBeNgEl | STAR-CCM+ | 0 | January 31, 2013 14:21 |
Axial fan simulation in UG/NX 7.5 | fan123 | Main CFD Forum | 2 | April 23, 2011 09:22 |
