Convergence problem
Old   June 25, 2020, 16:58
Default Convergence problem
Felipe Silva Maffei
Maffei is on a distinguished road
Hello everyone!
It is the second time that I have posted something on this forum, so, if I doing anything wrong, sorry. That said, lets to my question:
I am trying to simulate an incompressible jet pump. The boundary conditions was setup as normal velocity equal 1 m/s at secondary and primary inlets. At the outlet, it was used the outlet-pressure with reference pressure equal to zero and the wall with no slip conditions. The turbulence model used was the RNG k-epsilon. The mesh was built in the ICEM CFD using the structured type (finer elements was positioned near the walls).
I am using the SIMPLE solver with:
Gradient -> Green Gauss node based
Pressure -> Linear
Momentum, and tubulenty properties -> First order
URF -> fluent standard
I already try a lot of configuration, but I cannot avoid the behavior that is shown in the figure 1, thus, the residuals do not decrease. Way is it happen?
Fig1 -> Velocity field with the error highlighted with red line
Fig2 -> Mesh detail 1 at this region
Fig3 -> Mesh detail 2 at the region
Maffei is offline   Reply With Quote
Old   June 26, 2020, 09:32
acalado's Avatar
André
acalado is on a distinguished road
what are the residuals showing?
Is that first plot velocity or residuals? looks like velocity to me...
Sapere aude!
acalado is offline   Reply With Quote
convergence failure
Convergence problem in Fluent for quenching process kaeran FLUENT 4 December 1, 2014 03:14
Rotate frame reference convergence problem! wjy-c CFX 2 September 26, 2014 07:03
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 10:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 04:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
