Problem of boundary condition setting for natural convection in a water tank
Old   June 25, 2020, 04:26
Default Problem of boundary condition setting for natural convection in a water tank
Henry
haiteng is on a distinguished road
I am using ANSYS Fluent to simulate the experiment for natural convection of a single heated cylinder in a large water tank made of Plexiglas (approximated as thermal-insulating material), which is 1200 mm wide with a water depth of 1600 mm. Computational domain is a rectangular with the same width and depth as the experiment. The thrid dimension is neglected because it is assumed that spanwise flow field is uniform, which is reasonable. I use steady, pressure-based solver and Boussinesq approximation for buoyancy. Turbulence is modelled by transition SST.
The major problem I have is how to set the boundary condition correctly on the four sides of the rectangular domain. I have tried two options.
Option 1: No-slip, adiabatic wall on left, right & bottom boundary. Zero-shear, isothermal (Tw=293 K) wall on top boundary, to simulate the free water surface. This boundary condition setting is most representative of real scenario in experiment. However, the result is non-sensible. Contour of velocity magnitude suggests buoyant plume is completely disrupted, as attached in "Option 1".
Option 2: No-slip, adiabatic wall on left & right boundary. Pressure inlet at bottom boudanry. Pressure outlet at top boundary. This setting, although not representative of experimental scenario, produces sensible result. Buoyant plume show reasonable profile and velocity magnitude, as attached in "Option 2".
Could anyone tell me, why Option 1 generates the non-sensible result, although it is exactly the same as experiment? Why Option 2 seems so good, although the boundary condition does not reflect the real scenario?...
haiteng is offline   Reply With Quote
Old   June 25, 2020, 04:38
Default Conditions
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
It's not the boundary conditions, but the operating conditions that appear to be set incorrect. You need to check three settings
1. Gravity value and direction
2. Operating density should be same as Boussinesq density used in material panel
3. Boussinesq temperature; should be corresponding to the operating density
Second option, thought giving right results, is incorrect.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 25, 2020, 05:04
Henry
Thanks, Vinerm. But I don't think they could solve the problem.
I have checked the three settings and have not found anything dubious.
1. Gravity acceleration is -9.8 m/s2 on Y axis, i.e. vertically downward.
2. Operating density is not specified because it is not necessary when the Boussinesq model is used.
3. Boussinesq temperature is the ambient temperature, under which the Boussinesq density in material panel is evaluated.
Why the second option is incorrect?
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Radiation interface hinca CFX 15 January 26, 2014 18:11
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Problem setting boundary condition from file Antonis CFX 1 September 11, 2006 17:53
