Velocity Profile of previous simulation as inlet for another
Old   June 25, 2020, 03:06
Default Velocity Profile of previous simulation as inlet for another
GenD
GenD is on a distinguished road
I was wondering about cutting my simulation and geometry into some parts in order to meet computational possibilities of my computer and have better results. That's why I was thinking about putting velocity profile (or other if it's better) of outlet into inlet of next simulations. Is there a way to do this? Is it through UDF?
And the last question, is it a good idea generally? Will this approach affect on something badly?
GenD is offline   Reply With Quote
Old   June 26, 2020, 09:30
acalado's Avatar
André
acalado is on a distinguished road
You should be able to take the profile of one simulation and use that input into another simulation... but what exactly are you trying to model?
You can also specify periodic boundary conditions that take whatever goes through one boundary to feed it back into the other (e.g. in a pipe flow the flow going out through right comes right back in on the left which can allow you to study a fully developed flow in a relatively short domain)
Sapere aude!
acalado is offline   Reply With Quote
Old   June 26, 2020, 14:31
GenD
But how to connect those profiles? In this case, I'm not modeling anything. It's just a idea to be used in future, because of computer limitations. Let's say it will be some flow through tank with porous plates. I would have just divide this tank into ... three parts and then try to simulate it respectively.
Old   June 26, 2020, 17:57
acalado's Avatar
André
It sounds like you want to cut them to run it on different computers??
Sapere aude!
Old   June 26, 2020, 19:27
Lucky
It's a little confusing because there's a method of writing profiles in fluent that's quite literally called a profile. Write a PROFILE at the outlet of your first simulation and then read it into the next simulation. Then you can use this profile/PROFILE as a BC.
Old   June 27, 2020, 03:33
GenD
acalado, No, not on different computers. On the same one, but one simulation after another.
LuckyTran, that was my first thought to create a UDF. I know how to do this generally, but I don't really know how to read profile of outlet (it won't be pretty laminar flow, but highly turbulent) in a form, which can be used then as Profile UDF of inlet. Do you know some useful macros or tips in order to do this?
Old   June 27, 2020, 09:39
Default Profile
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
You don't require a UDF. Profile is written using File > Write or using TUI commands for the same. You need to write profiles for each field variable and not just velocity. Reading profile is same as writing, i.e., File > Read and then go to the boundary to apply the profile.
However, there is one concern and it could have very significant effects. If the flow is unidirectional at the location where you cut the domain, then it is alright, otherwise, this would require multiple iterations, i.e., you have to do calculations for each domain many times if the profiles at the boundaries are not unidirectional.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 27, 2020, 20:37
GenD
Sounds like a simple plan. I will try to achieve it, when I will model something worth of trying. Thanks for your help.
Offtopic: Do someone have idea by which UDF macro I can read data of profile?
Old   June 28, 2020, 04:27
Lucky
You don't need a UDF, stop obsessing over it
cfd, few simulations, profile
UDF - Inlet Velocity Profile (Ansys Fluent) vinayak4399 Fluent UDF and Scheme Programming 3 August 25, 2020 15:15
Inlet velocity profile question dmirel STAR-CCM+ 4 October 8, 2019 05:42
Simulation Pausing Durning Velocity Profile Update CaptainCombo ANSYS 1 September 4, 2015 11:55
3d velocity profile at velocity inlet swethaprakash FLUENT 3 September 1, 2015 03:10
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 14:02
