Presto!
Old   June 22, 2020, 08:51
Default Presto!
Raymond_1981 is on a distinguished road
Hi guys,
I have some difficulties understanding how the PRESTO! scheme works.
The theory guide says: "The PRESTO! (PREssure STaggering Option) scheme uses the discrete continuity balance for a “staggered” control volume about the face to compute the “staggered” (that is, face) pressure. This procedure is similar in spirit to the staggered-grid schemes used with structured meshes [365] (p. 795)."
Does this mean that the pressure is seperatly calculated at the cell faces and stored there? Does anybody know how this is calculated?
I cannot find a paper or book where the PRESTO! scheme is explained in detail.
Cheers!
Raymond_1981 is offline   Reply With Quote
Old   June 22, 2020, 09:20
Default Presto
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
It is same the method described in Patankar's book, with modifications to suit unstructured meshes.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 22, 2020, 12:26
Hi vinerm,
Thanks for your response. I have read the chapter about staggered grids in Patankar's book. To summarize (check if I have understood correctly), the pressure is calculated and stored on a staggered grid where the locations of the nodes is determined by some sort of algorithm in Fluent. Interpolation of the pressure is therefore no longer required, since it is stored at the correct location.
Does the part "discrete continuity balance" mean that they have rewritten the discrete continuity equation to incorporate the pressure term, like the pressure Poisson equation?
presto!
Convergence Problem with PRESTO! teimur FLUENT 0 June 4, 2017 14:31
Problem with Presto! scheme using cartesian mesh lakhi FLUENT 0 October 3, 2014 15:48
Impossible Results using PRESTO! Scheme Kaaji1359 FLUENT 0 August 27, 2014 18:52
Fractional Step, PRESTO! & LES Paolo Lampitella FLUENT 2 December 1, 2007 02:46
Presto scheme Christian FLUENT 0 April 14, 2003 04:49
