csf models couple with dynamic mesh
Old   June 22, 2020, 00:13
Question csf models couple with dynamic mesh
Cheng CHEN
OtisChen is on a distinguished road
Dear all:
I was studying a question which needs to couple with CSF model(to calculate surface tension) with dynamic mesh in two phase flow. However, CSF model requires quadrilaterals or hexahedra cell type and dynamic mesh requires triangular and tetrahedral cell type. I want to know if there is a method to balance the problem.
Best Regards
Cheng Chen
OtisChen is offline   Reply With Quote
Old   June 22, 2020, 05:14
Default Csf
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
There are no such requirements of CSF. It works with all types of meshes.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 22, 2020, 05:26
Cheng CHEN
The CSF model can indeed use different types of grids.However, except quadrilateral and polyhedral mesh, patched liquid level will be uneven, which will cause a large error in surface tension calculated by CSF.
Old   June 22, 2020, 05:30
Default CSF and DM
vinerm's Avatar
Vinerm
Yes, that is certainly the case, but you have to find a compromise. And it also depends on the motion of the boundary and its proximity to the interface.
Regards,
Vinerm
Old   June 22, 2020, 05:48
Cheng CHEN
My model is an open channel flow of boat, so it's really hard to balance.I want to know whether Cutcell remeshing method is available. I generate Cartesian grid in ICEM and select Spring Smothing method in Fluent, but this will cause MPI.When diffusion is selected, it indicates that the current diffusion method is not applicable to the polyhedral mesh.
Old   June 22, 2020, 06:00
Default Smoothing
vinerm's Avatar
Vinerm
If you are only using smoothing, then you can work with full hex as well. However, if you are using remeshing, then hex won't work. I am not sure whether new version handle cutcell or not. But you can try with overset. That could be a better alternative to deforming mesh.
Regards,
Vinerm
Old   June 22, 2020, 06:07
Cheng CHEN
Thank you. I'll try the overset.
sincerely!
Dynamic Mesh kennyboy FLUENT 1 February 23, 2019 02:52
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 11:08
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 09:00
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
