Convection problems in a greenhouse
Old   June 21, 2020, 11:04
Default Convection problems in a greenhouse
Taynan Almeida
taynanalmeida is on a distinguished road
I'm currently trying to simulate the effects of two exhaust fans in greenhouse. It seemed ok until I decided to try an extreme test which I set the free stream temperature in 600 ºC, the initial temperature inside the greenhouse in 35 ºC and the pads that are responsible to refrigerate the environment are set in 15 ºC. The fans have a mass flow around 11 kg/s. In the end of the transient simulation (100 s) the internal temperature is the same as the pad's temperature, as you can see in the picture.
I have already tried:
1- Incompressible fluid approximation
2- Boussinesq approximation
3- Set the free stream temperature in 600 ºC (Convection thermal condition)
4- Set the walls temperature in 600 ºC (Temperature thermal condition)
Do you have any idea about what am I doing wrong?
Thank you.
taynanalmeida is offline   Reply With Quote
Old   June 21, 2020, 17:23
Default Free Stream Temperature
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
What is meant by free-stream temperature? Is the temperature you are using for a wall boundary with convection condition or do you mean temperature of the incoming air? Essentially, both should be same since the air outside is the one being sucked in by the fans.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 21, 2020, 18:09
Taynan Almeida
The free stream temperature is the one outside the greenhouse.
I've uploaded a picture with the boundary conditions I've used.
Old   June 22, 2020, 04:59
Default Thermal Field
vinerm's Avatar
Vinerm
What is the temperature at the inlet? It should be same as free stream temperature used for wall boundary. If it is not, then, the results are as expected.
Regards,
Vinerm
Old   June 22, 2020, 10:32
Taynan Almeida
The inlet temperature comes from the water passing through the pads and it's lower than the free stream temp. I've started the simulation with a temperature of 600 ºC inside and outside the greenhouse now, and the pads are set in 25 ºC. In the end of the simulation the temperature inside is the same as pads' temperature, and I imagine that at this circumstances it would be impossible to let the temperature thaat lower than the temperature outside. Is it possible that the time I'm using for the simulation is to short (200 s)?
Old   June 22, 2020, 11:27
Default Inlet Temperature
vinerm's Avatar
Vinerm
I am sorry, but you have not provided answer to a simpler question; what is the temperature at the inlet? Because a whole lot depends on that.
Regards,
Vinerm
Old   June 22, 2020, 11:30
Taynan Almeida
The pads are the inlet, the temperature is 15 ºC.
Old   June 22, 2020, 11:35
Default Temperature
vinerm's Avatar
Vinerm
If the inlet temperature is 15, then most of the temperature will be 15. Only very close to the walls, temperature might be slightly higher, but not much because HTC on the outside walls is too small.
Regards,
Vinerm
Old   June 22, 2020, 11:41
Taynan Almeida
Hmm, I got it. I've tried another situation in which I set the wall temperature in 600 ºC and in this situation is not necessary to provide the HTC, only the surface temperature (wall temperature) and I still have the same answer. Is it supposed to be this way?
Because it seems to me that with a high temperature on the walls, the inside temperature is most likely to be closer to 600 ºC.
Old   June 22, 2020, 11:47
Default Physics
vinerm's Avatar
Vinerm
Temperature does not do anything on its own. Its the mechanisms of heat transfer that do the job. I suppose you are not considering radiation as of now. So, lets look at the other two modes, convection and conduction. If the flow velocities are very high, then convection rate would be high, implying the heat coming in from the walls will be carried away by the moving fluid. So, if you check the temperature at the outlet, it would be slightly higher than incoming one. Since there is no radiation, and most of the flow is going from inlet towards outlet without much recirculation, it is only conduction that is responsible for transporting thermal energy from the walls to the interior. The conduction depends on turbulence, if the flow is turbulent, else only on the thermal conductivity. If the flow is turbulent, you should observe some thermal boundary layer adjacent to the walls.
Reduce the flow rate to a very small value since 11 kg/s could be large value for flow rate of air. Set it to 1 or lower and you will see the effects. However, actual simulation should be done with whatever is the flow rate of the fans used; do check for their accuracy though because 11 kg/s is very high.
Regards,
Vinerm
Old   June 22, 2020, 12:26
Taynan Almeida
Ok, I got the first part. About the flow rate I'm using the information provided by the fan supplier as you can see in the picture. The static pressure ir around 12 Pa. Converting m³/h in m³/s and multiplying by the air density we have something around 11 kg/s, am I right?
Old   June 22, 2020, 12:38
Default Flow Rate
  #12
vinerm's Avatar
Vinerm
If the flow rate is correct, then so is the thermal contours, assuming you have included the required models, such as, turbulence.
Regards,
Vinerm
Old   June 22, 2020, 13:03
Taynan Almeida
The turbulance model was missing. I am using know the K-epsilon to simulate that extreme situation.
As a matter of fact, my simulation is quite different and the real values are:
Free stream temperature: 34 ºC
Inlet temperature: 25 - 27 ºC
Temperature inside the greenhouse is 35 ºC (starting value)
Can you advise me another turbulence model or this one that I'm using is ok for this situation? Is it ok to use the default values provided by the software?
Old   June 23, 2020, 05:01
Default Turbulenc
  #14
vinerm's Avatar
Vinerm
Realizable k-\varepsilon is alright. Use actual conditions. Default values are good.
Regards,
Vinerm
Old   July 9, 2020, 12:52
John Wilson
JohnieWilson26 is on a distinguished road
Hi I tried to do a similar thing with my old greenhouse but unfortunately it didn't work out. I thought that the problem was in my method but actually my greenhouse was pretty old and kinda broken. I didnt know what to do but a friend of mine told me that it is better for me to buy a new greenhouse. I didnt really know where or which greenhouse to buy. But in the end I decided that it is way easier to buy greenhouse online. If you decide to replace your greenhouse I can suggest you this guys from South West store https://www.swgreenhouses.co.uk/, they can help you pick the best greenhouse for your projects and even delivered it for free. I did buy a greenhouse from other webservice but I believe this service is pretty good too.
JohnieWilson26 is offline   Reply With Quote
convection heat flux, convection schemes
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 05:12
Convection Term Discretization Maciej Matyka Main CFD Forum 3 October 7, 2004 05:32
natural convection again Jan Langebach FLUENT 2 September 30, 2004 08:40
problems in natural convection nabeel FLUENT 19 August 6, 2004 01:52
CFX-5.5 simulating air free convection Dustin Lee CFX 0 April 16, 2003 03:54
