Transition prediction and validation of flat plate using fluent transition SST model
Old   June 19, 2020, 11:02
Default Transition prediction and validation of flat plate using fluent transition SST model
Cambridge is on a distinguished road
Dear all,
I have a question about the validation of flat plate transition as I need to replicate some references.
1. What is the exact turbulence of Schubauer-Klebanof's experiment?
As the attached file menter2006, turbulence is 0.18% but in menter2015, it is 0.03%. I have checked the original experiment, I can only find 0.03%.
2. Why can't I replicate the skin friction coefficient result of Schubauer-Klebanof's experiment by using fluent and transition SST model (gamma-theta model)?
As I followed the latest paper menter2015, I set the turbulence to 0.03%, but the result shows the transition point is near x=1.15m, not same as both S&K's experiment and menter2015's result, where the transitional point is near x=0.8m. When I changed to transition kkl omega, it becomes right. Why can't I get that result by using transition SST model?
I am a student and new in this area, and really hope someone could help me, thank you so much.
Sincerely
Cambridge is offline   Reply With Quote
Old   June 19, 2020, 11:32
Default Contributions on the mechanics of boundary-layer transition
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
You can check it yourself
https://ntrs.nasa.gov/search.jsp?R=19930092285
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 20, 2020, 06:08
Originally Posted by vinerm View Post
Hi
Thank you.
I have checked before but can only find 0.03% turbulence, but many papers used 0.18% and even menter2006 has ever used 0.18%. This is very important to me as I can not replicate S&K by setting 0.03% and using transition SST model.
flat plate, fluent, transiton model, validation
Separation Prediction with Menters SST k-omega Jonas Larsson FLUENT 5 March 20, 2002 14:44
