Pressure-far-field condition setting
Old   June 18, 2020, 09:08
Question Pressure-far-field condition setting
wongsatorn
son1122 is on a distinguished road
hi, guys, .i have a problem with pressure far-field boundary condition. I want to practice and validate CFD result form CFD Computation of Magnus Moment and Roll Damping Moment of a Spinning Projectile by James DeSpirito and Karen R. Heavey
and I see https://www.youtube.com/watch?v=uhBtGrxZlpY&t=750s that show how to set this condition. however, my residual seems to be divergence and flow field seems to be incorrect as you can see
anyone has any idea ? thank you
son1122 is offline   Reply With Quote
Old   June 18, 2020, 13:29
Default Setting
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
You should include the far-field settings that you are using as an image in the post. Furthermore, I suppose you have already set operating pressure as 0 and material density as ideal gas. Try fmg initialization. If the case fails to initialize with fmg method, then there is some problem with the setup.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 20, 2020, 08:26
wongsatorn
thank you for your reply My set up is wrong as you say because of over turbulent parameter. thank you so much vinerm.regard
fluent
Pressure fields in FOAM, p field, total pressure, etc. Tobi OpenFOAM Post-Processing 9 March 25, 2022 02:33
[waves2Foam] zeroGradient boundary condition for the outlet's pressure field? Behrang OpenFOAM Community Contributions 1 February 28, 2014 14:09
how to replace a shock tube high pressure port by a boundary condition? immortality OpenFOAM Pre-Processing 0 May 2, 2013 14:43
Setting Pressure Condition marcoymarc CFX 15 December 5, 2012 09:28
Warning 097- AB Siemens 6 November 15, 2004 05:41
