duel energy equations of porous media in fluent
Old   June 17, 2020, 01:15
Default duel energy equations of porous media in fluent
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I am modeling fuel combustion in porous zone with fluent. The temperature is different between porous solid and fluid locally. In other words, the solid and fluid are in non thermal equilibrium state. However, I don't want to use the in-build non thermal equilibrium model of fluent. Instead I want to use dual energy equations to solve fluid and solid temperature separately.
The general idea is to use a UDS to solve solid temperature in which I can define source term, diffusion coefficient and so on. The energy equation of fluid is solved by fluent automatically. However, I have two confusions before I can start my modeling work.
Firstly, although I use a UDS to solve solid energy equation, fluid still solves energy equation of fluid assuming thermal equilibrium state. In other words, the conduction term, unsteady term of fluid equation still solves in a volume averaged method. I mean should I modify the energy equation of fluid energy equation to make it non-volume averaged?
secondly, I have chemical reactions in fluid domain. Then how to deal with source terms caused by chemical reactions to fluid and solid. My thinking is to assume combustion source term is only added to fluid energy equation by default. And then, fluid and solid exchange heat by user defined source term?
Best regards
Weiqiang
Weiqiang Liu is offline   Reply With Quote
dual energy equation, non thermal equilibrium, porous media, uds
modeling the fluid flow in porous media by Fluent Mohsen Nazari FLUENT 5 April 26, 2019 05:45
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
Momentum equation Fluent uses for flow through porous media 0906536m FLUENT 0 July 6, 2015 16:54
energy equation in porous media? Tony FLUENT 1 June 9, 2015 14:41
Fluent porous media lostinicem FLUENT 3 January 26, 2012 11:35
