Radiation through semi-transparent wall (DO model) |
June 16, 2020, 12:42 |
Deutschland
Dear community,
I´m new here and looking forward to get help and learn more about Ansys CFD. I´m working with Fluent to model a double skin facade. I created a 2D Model which consinst of two wall boundaries for the two layers of facade glass and an atmosphere in front of the first layer of glass. The radiation is implemented on a semi-transparent wall on the outer edge of the atmosphere. Unfortunately the radiation will not be transported through the semi-transparent wall representing the glass pane of the facade. Does anybody know why that is? I gave the wall a thickness and defined the material glass. The wall is coupled. The description of the model and the result are in the pictures: https://gigamove.rz.rwth-aachen.de/d/id/onbqYsPyD9Bkrg https://gigamove.rz.rwth-aachen.de/d/id/YLReBoyvsavWJY I would really appreciate some thoughts on this topic. Thanks a lot already. |
November 11, 2020, 09:37 |
Semi-Transparent Medium
#2 | |
Lucas Leocadio Battiston
Rep Power: 6 |
Hello CB, I'm else working with semi-transparent medium. You can trate this medium like a frozen fluid. Set frozenFlow in fvSolution and its done, you can solve the RTE with P1 or fvDOM. att, Lucas L. Battiston |
radiation do model |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 18:19 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 22:16 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 06:41 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
