generic_property: not a generic method
Old   June 16, 2020, 07:08
Default generic_property: not a generic method
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I am using DEFINE_PROPERTY macro to define thermal conductivity of fluid. I can compile and load UDF normally. However, fluent keeps complaining following error :
"Internal error at line 200 in file 'material\prop.c' on Node 3.
generic_property: not a generic method"
I am wondering why would this happen and how can I avoid this?
Best regards
Weiqiang
Weiqiang Liu is offline   Reply With Quote
Old   June 16, 2020, 07:35
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
You might be using generic_property in an incorrect manner.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 16, 2020, 09:17
Weiqiang Liu
I just copied this code from official UDF manual. Maybe I missed the name of generic_property?
Old   June 16, 2020, 09:45
Default Function
vinerm's Avatar
Vinerm
Do note that generic_property function works only with species transport model enabled.
Regards,
Vinerm
Old   June 16, 2020, 09:50
Weiqiang Liu
yes, I always open species transport model in my case. thanks for reminding!
Old   June 16, 2020, 12:17
Default Copying
vinerm's Avatar
Vinerm
Did you copy the code from the manual as it is using Copy procedure or did you type it yourself? If it is the former, then that won't work. You need to open the file in text editor, select it, and copy it to another file. Preferable would be to type it yourself in a new file.
Regards,
Vinerm
define property, generic method, internal error
Inaccurate gradient results from continuous Adjoint method Yminjo SU2 1 January 11, 2014 23:08
multiphaseEulerFoam: method mag(...) withing method solveAlphase() maybee OpenFOAM Programming & Development 0 December 21, 2013 11:13
Help about the preconditioner in gmres method Dan Gao Main CFD Forum 3 July 5, 2008 02:18
About flowfield-dependent variation(FDV) method? Jinwon Main CFD Forum 1 December 4, 2007 22:13
tidal flow simulation using finite volume method Jason Qiu Main CFD Forum 0 October 20, 2002 03:34
