Unable to calculate pressure drop in Preiodic Boundary condition in Fluent |
Madhu Kalyan
Rep Power: 6 ![]() |
So I took a simple problem of a 2cm x 2 cm x 5cm duct and gave a mass flow rate of 1kg/s with air as the fluid in order to simulate periodic BC over a total length of 50 cm. If I give the specified pressure drop and simulate the model I get the exact massflow rate but if I give the mass flow rate my pressure drop is giving bad numbers. What is the problem?
Do note that the pressure gradient is given as per m of length. And by bad, how bad do you mean?
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Madhu Kalyan
By bad I mean almost zero pressure gradient. And yes iam talking about the pressure drop per length
fluent, periodic boundary fluent |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Pressure boundary condition ANSYS Fluent | aggie | FLUENT | 6 | April 25, 2012 01:39 |
