June 14, 2020, 05:27 |
UDF for multiphase flow:error
Arun raj.S
Rep Power: 16 |
I have compiled the following UDF in parallel mode of v20.1 student version and receive the following error.
Creating user_nt.udf file for 2ddp_node ... (system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v201\fluent"\fluent 20.1.0\src\udf\makefile_nt.udf "libudfM\win64\2ddp_node\makefile" ") 1 file(s) copied. (chdir "libudfM")(chdir "win64\2ddp_node")# Generating ud_io1.h mass.c ..\..\src\mass.c(26): error C2109: subscript requires array or pointer type ..\..\src\mass.c(27): error C2109: subscript requires array or pointer type ..\..\src\mass.c(27): error C2198: 'sqrt': too few arguments for call #include "udf.h" #include "math.h" #define M 18.015 #define hfg 2600000.0 #define R 8314.0 #define pi 3.141592 #define pref 101325 #define Tref 373.15 #define pv 15828.0 #define Tv 343.0 DEFINE_SOURCE(mass,c,t,dS,eqn) { real source, pv_eq, Tlv, vol, Acell ; Thread *t_int; face_t f_int; real area; Domain *domain; domain = Get_Domain(1); t_int = Lookup_Thread(domain,3); /*3 is the zone id for the boundary where source term is to be applied*/ begin_c_loop(c,t) { int i = 0; f_int = C_FACE(c,t,i); F_AREA(area,f_int,t_int); Acell = NV_MAG(area); Tlv = C_T(c,t); vol = C_VOLUME(c,t); pv_eq = pref * exp(((M*hfg)/R) * ((1/Tref)-(1/Tlv))); source = - 0.857142857 * (Acell/vol) * SQRT(2*M/pi*R) * (pv_eq/SQRT(Tlv) - pv/SQRT(Tv)); dS[eqn] = 0.0; } end_c_loop(c,t) return source; } |
June 15, 2020, 08:20 |
Define_source
DEFINE_SOURCE is executed on each cell of the cell zone it is hooked to. So, do not loop over the cells again. And C_FACE is available only within a c_face_loop. I suppose you intended to use that one instead of begin_c_loop.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
udf for one dimensional linear motion based on force | maccheese | Fluent UDF and Scheme Programming | 2 | September 1, 2019 03:18 |
Save output of udf in another udf! | JuanJoMex | FLUENT | 0 | February 8, 2018 13:43 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 01:53 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
