June 13, 2020, 10:21 |
UDF using streamline coordinate?
Rep Power: 7 |
I can't find anywhere on Fluent which uses streamline coordinate. For instance, I need the flow velocity along the streamline and the derivative of the velocity w.r.t. the normal of its streamline.
Fluent's x[ND_ND] seems to be for x-y Cartesian coordinate and likewise is its velocity gradient (C_DUDX). Is there anyway I can convert to streamline coordinate? |
June 15, 2020, 08:02 |
Coordinate Transformation
The only coordinate available in Fluent is spatial and that's too in Cartesian. One solution is to write the pathlines. Those are nothing but particles tracks for massless particles. These will have all the information you need, i.e., velocities at each point on the path, representing streamlines and then you can determine gradient using difference in velocities along the normal, which essentially requires calculation of curvature.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
coordinate, streamli, udf |
Error code: 126 when loading parallel UDF | Coop | Fluent UDF and Scheme Programming | 0 | July 13, 2018 08:33 |
How to get the local coordinate Z via UDF or other way in Fluent | JoaoSilva | Fluent UDF and Scheme Programming | 0 | July 17, 2015 07:33 |
UDF doesn't work how I need it to - problems with the coordinate system in Fluent | SarahG | Fluent UDF and Scheme Programming | 10 | January 25, 2015 16:51 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 07:26 |
radial coordinate in UDF | varghese | FLUENT | 1 | September 25, 2003 09:43 |
