June 9, 2020, 15:20 |
Fluent Radiation Model
j
I'm trying to include some very simple radiation in my computation. I'm reading through the different models but I'm not sure which is best to use for what I want. I have a conjugate simulation and one of my external boundaries is exposed to the environment. I'd like to include radiation from that surface (I know the emissivity of the surface) to the surroundings. I'm not sure which is best, and I know in some other CFD packages you can specify a surroundings temperature. I don't see this is 2019R2 Fluent. Thanks for your help!
June 15, 2020, 06:46 |
Radiation Model
A radiation model is used only if radiation is to be modeled within the domain. If you want to model the effect of the incident radiation on the external boundaries of the domain, then you don't need a radiation model, only a radiation boundary. Just enable it for wall and provide the wall emissivity and radiation temperature.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Fluent - Solar Radiation Model | calvinlai | FLUENT | 1 | September 15, 2017 06:35 |
Solver refuses to run: Monte Carlo Radiation Model | Zaphod'sSecondHead | CFX | 9 | February 14, 2017 09:20 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
problem in glass radiation model (DO model) | wunan805 | FLUENT | 0 | October 10, 2012 05:06 |
definition difficulty-->DO radiation model | Harry Qiu | FLUENT | 0 | March 29, 2001 09:19 |
