Premixed Combustion
Old   June 9, 2020, 15:03
Default Premixed Combustion
Krutika Appaswamy
Krutika Appaswamy is on a distinguished road
I am trying to setup premixed combustion with multiple inlets and a coflow. How should the materials be specified for each inlet?
Also, Should the backflow progress variable be 1?
Thanks!
Krutika Appaswamy is offline   Reply With Quote
Old   June 15, 2020, 07:43
Default Material and Boundary
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Material is not defined for inlet but for the cell zones. And for premixed combustion, everything is premixed. The only difference across the boundaries could be the fraction of unburnt material, defined using progress variable.
At the outlet, progress variable should be defined as per the expected conditions. If it is expected that the combustion will be complete by the time fluid reaches the outlet, then use a value of 1, otherwise, a value lesser than 1. Do note that this value is used only in case of flow reversal, not otherwise.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
non premixed combustion with ''compressibility effects'' enabled Muneeb FLUENT 5 November 15, 2018 03:06
Modelling of premixed combustion in a burner rig ThomasS FLUENT 12 September 7, 2018 14:07
partial premixed combustion model early combustion than expected omaradel FLUENT 0 June 27, 2017 15:38
How to model premixed combustion using partially premixed combustion model in Fluent? sab10012 FLUENT 0 October 6, 2015 02:18
Partially Premixed Combustion - Direct Fired Boiler oknus FLUENT 0 April 10, 2012 11:52
