Moving Reference Frame - Unaffected Fluid
Old   June 6, 2020, 14:35
Unhappy Moving Reference Frame - Unaffected Fluid
Mr.Freeze is on a distinguished road
Hello, everyone,
I have a problem and I'm hoping that someone here can help me with it. I want to use Moving Reference Frame to simulate the fluid flow and heat transfer between two gears within a gearbox. Unfortunately, I couldn't find anything about this in the tutorials by Ansys on Youtube or in the Users Guide by Fluent. Most things are too general and can't clarify my problem.
My main problem is the following: I don't know what has to be set in the Boundary Conditions and Cell Conditions to make the gears move and influence the fluid. So far I have activated the Frame Motion in the Cell Conditions, but left the rest on default. For the solid parts in the Cell Conditions I have also activated the Frame Motion. I have also done this with the affected Boundary Conditions. Unfortunately only the gears are turning but the fluid is completely unaffected.
Can anyone help me that the fluid is influenced by the rotation of the gears with the help of MRF. I use the MRF for a first overview. After that I want to create Momentum Source and later a Moving Deforming Mesh.
I already want to thank you for your efforts.
Mr.Freeze is offline   Reply With Quote
Old   June 6, 2020, 17:12
Default Gears Motion
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
If the gears are meshed (as in gear meshing not CFD meshing), then you cannot use either frame motion or mesh motion. The only option is to use dynamic mesh. Frame or mesh motion for rotation works only if you have a surface of revolution dividing stationary and rotating zones. In case of single gear or two unmeshed gears, it is possible, but two gears meshed with each other, the only possibility is with dynamic mesh.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
ansys, fluid, moving reference frame
[OpenFOAM.com] An Error in recompiling of openFoam-4.0 alimea OpenFOAM Installation 4 April 8, 2020 15:44
Single moving reference frame vs Multiple reference frame for Wind Turbine CFD mrswordf1sh FLUENT 4 January 25, 2020 09:43
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
