How to simulate a porous media which is opaque to thermal radiation in Fluent Ansys?
Old   June 2, 2020, 12:33
Default How to simulate a porous media which is opaque to thermal radiation in Fluent Ansys?
mz_uon is on a distinguished road
Hello
I am trying to model a porous zone in Fluent (the fluid in void is air) which is opaque to thermal radiation. If I set it as a porous zone with air as the media, Fluent treats it as a transparent zone and the thermal radiations do not interact. The zone is only opaque if I set it as a solid zone (with boundary condition set to wall), however in this case air won't flow through it. The aim is to simulate a porous zone within a larger domain.
Is there a way to combine them, to model a zone which is porous while also being opaque to thermal radiation (something like a sponge, opaque to thermal radiation but allows airflow through it).
Thanks
mz_uon is offline   Reply With Quote
Old   June 2, 2020, 12:38
Default Opaque Region
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
A porous region in Fluent is fluid region. And to make it opaque, just set its absorption coefficient to 1.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 2, 2020, 12:47
You mean changing the absorption coefficient of the fluid?
So, in this case, it is air, since it is a porous zone. But then the entire domain becomes that as the fluid is air throughout.
Old   June 2, 2020, 12:51
Default Opaque
vinerm's Avatar
Vinerm
Dry air does not participate in radiation, i.e., its absorption and scattering coefficient are very very low. However, a porous zone consists of two domains, a solid and a fluid. As long as you use equilibrium model, i.e., assumption of same temperature for fluid and solid, you need to modify absorption coefficient of the air as well as that of the solid material representing the solid region. If you use non-equilibrium model, then you can change material properties only for the solid region.
Regards,
Vinerm
Old   June 2, 2020, 13:08
I am using an equilibrium model for heat transfer (see image). However I don't see the option to change the absorption coefficient of the solid material.
As for the fluid, I created a copy of 'air' and set its absorption coefficient (AC) to 1. So the air in the domain has AC set to 0 and air in the porous zone has AC set to 1. Am I doing it correctly?
Old   June 2, 2020, 13:12
Default Radiation Parameters
vinerm's Avatar
Vinerm
Which radiation model are you using?
Regards,
Vinerm
Old   June 2, 2020, 13:15
P1, solar loading (see image)
What do you suggest can be done?
Old   June 3, 2020, 10:29
Default Radiation Model
vinerm's Avatar
Vinerm
In case of P1, radiation properties are not required for solid. Solids are opaque to the radiation in the sense that they block it.
Regards,
Vinerm
Old   June 3, 2020, 12:55
But my porous zone is not behaving like that. It is totally transparent to the solar radiation. I have made sure to check the 'participate in radiation' option for that zone too.
Old   June 3, 2020, 13:27
Default Absorption Coefficient
vinerm's Avatar
Vinerm
Despite using an absorption coefficient of 1. Do note that an absorption coefficient of 1 also implies emission coefficient of 1. So, the fluid zone may not be transparent but emitting the radiation.
Regards,
Vinerm
Old   June 3, 2020, 13:34
How do I overcome this?
Simply put, I have a porous zone within a larger domain. The fluid is air flowing in the region. Solar radiation is activated. The aim is to investigate the impact of wind speed and porosity on the temperature around the porous zone.
Don't want to spend too much time and effort modeling it on Fluent, an approximate model is fine.
Old   June 3, 2020, 14:13
Default Solar Radiation
  #12
vinerm's Avatar
Vinerm
If it is only solar radiation, then you don't need to enable radiation model. Solar radiation is different and can be used exclusive of radiation model.
Regards,
Vinerm
Old   June 4, 2020, 07:04
Hi
I have updated the settings based on your suggestion (see image). However, I see no impact of this. My porous zone is still transparent to the solar radiation.
Can I upload my file here for you to have a look?
Thanks
Old   June 4, 2020, 07:09
Default Transparency
  #14
vinerm's Avatar
Vinerm
How are you determining that the zone is transparent? If the radiation model is turned off, there is no question of transparency or opaqueness.
Regards,
Vinerm
Old   June 4, 2020, 07:15
I have attached a snapshot of the model. Since there is 0 solar radiation on the porous region and all of it passes through onto the ground, it means that the porous zone is transparent to the solar radiation.
What I am trying to achieve is that this porous zone will cast a shadow, since it will block the solar radiation. I need to use a porous zone in this case because the air is still flowing through it.
Old   July 1, 2020, 11:00
Some help here will be appreciated.
Thank you
ansys, fluent, porous, solar radiation
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
analysis of multiphase and porous media in ansys fluent ahmed_khatibs FLUENT 0 November 4, 2014 13:01
local thermal non equilibrium model in porous media adi.ptb Fluent UDF and Scheme Programming 0 November 1, 2014 16:00
Modeling porous media with FLUENT newcomer FLUENT 4 September 26, 2013 01:08
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
