June 2, 2020, 11:16 |
Question on DEFINE_HEAT_FLUX
Rep Power: 6 |
Hi there,
I'm doing a fluid-solid coupling heat transfer problem. Since I've just started using Fluent, I've created a very simple test case (no radiation) to figure out what Fluent can do (attachement): 1.png Based on the description of udf DEFINE_HEAT_FLUX, it modifies the diffusive heat flux coefficients using equation: qid = cid[0] + cid[1]*C_T(c0,t0) - cid[2]*F_T(f,t) - cid[3]*pow(F_T(f,t),4) so I wrote the udf: DEFINE_HEAT_FLUX(heat_flux, f, t, c0, t0, cid, cir) { real h=2000.; cid[1] = h; cid[2] = h; cid[0] = 0.; cid[3] = 0.; C_UDMI(c0,t0,1)=h; } Then I got questions about the result, it seems really strange for me. 1. I tried to visualize C_UDMI(c0,t0,1) in the result. Instead of showing 2000 in some near wall cells, the max of the contour is somewhere around 1500 or 1000, not 2000, why? 2. What exactly this udf modified? In the figure that I uploaded, h(T_f-T_interface)=-k_wall*(T_interface-T_wall)/d2 where h is the coefficient assigned using udf, k_wall is the wall conductivity. is this correct? Thanks for your help. |
June 2, 2020, 11:41 |
Define_heat_flux
This function could have many uses, such as, modeling a phenomenon that is not being resolved. The objective is to modify the relation between heat flux and temperature. And it is not supposed to be used for CHT problems. If you expect the system to behave as it should for a solid-fluid pair, then do not use DEFINE_HEAT_FLUX function.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 2, 2020, 11:54 |
#3 | |
Rep Power: 6 |
Thanks for you reply. Could you please give me an example of "a phenomenon that is not being resolved"? and how does it "modify the relation between heat flux and temperature"? I tried to model the system as a normal solid-fluid pair (hot fluid passes through a cylinder, and we would like to predict the temperature on the outer cylinder wall surface), the prediction does not match the experiments. regards, |
June 2, 2020, 12:13 |
Conjugate Heat Transfer
To model normal solid-fluid pair, just do the simulation without any UDF. Ensure that the solid has at least four cells across its thickness and there are not pyramids at the fluid-solid interface.
Unresolved phenomena could be of any nature, say, thermal energy transfer by ions or by magnetic lines of force that are not being resolved, but are affecting the thermal distribution for a specified flux. Then, user can modify the coefficients in such a manner so as to include these extra effects.
June 2, 2020, 12:29 |
#5 | |
Rep Power: 6 |
Now I understand DEFINE_HEAT_FLUX seems not be a good option for normal CHT problems. In fact, modelling this problem (hot fluid passes through a cylinder, and predict the temperature profile on the outer cylinder wall surface as a function on time) is the first step of my project. It can be regarded as a first step to get familiar with fluent. The final objective is to change that pure fluid region to a porous medium region (the other stuff rest the same). I know in Fluent, we can model the thermal behaviour inside a porous medium, but when it comes to coupling the porous media with a solid wall. Does it the same as fluid-solid CHT problem? Do you think DEFINE_HEAT_FLUX can be useful in this situation? |
June 2, 2020, 12:33 |
Udf
I don't have your complete project description, however, looking at what you described, you will not require DEFINE_HEAT_FLUX. Fluent can directly work with heat transfer between fluid medium and its solid part in porous region as well as between fluid-porous-solid domains.
June 2, 2020, 12:45 |
#7 | |
Rep Power: 6 |
May 19, 2023, 04:34 |
sachin
Rep Power: 10 |
I am trying to implement the RPI wall boiling model as a user-defined function in Ansys Fluent. Is the Define_HEAT_FLUX macro need to be used for it? How to give the liquid side coefficients and phase change coefficients separately with this macro.
Any help on this will be appreciable. |
ansys, define_heat_flux, fluent, heat flux, udf |
Question about symmetry in Autodesk Cfd 2016 | ecto | Autodesk Simulation CFD | 0 | October 20, 2015 05:16 |
small question about the functionalities of topological changes in OpenFoam | ngj | OpenFOAM Running, Solving & CFD | 2 | February 28, 2013 11:02 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 14:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 16:26 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 05:37 |
