How to make intervals in an ANSYS Fluent user defined function UDF to describe three
Old   June 2, 2020, 06:06
Default How to make intervals in an ANSYS Fluent user defined function UDF to describe three
Have a nice time!
Ahmed Saeed Mansour is on a distinguished road
Hello, I have a plot shows the change of a quantity with time. How can we write a code in Fluent UDF to compile it ? I need a way to define the time intervals. From start to a specific moment, the quantity follows a specific relation, then it changes twice.
Thank you very much !
Ahmed Saeed Mansour is offline   Reply With Quote
Old   June 2, 2020, 06:26
Default Input
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Do you want to provide this profile as input to Fluent? Then you don't need a UDF. Use transient Profile file.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 3, 2020, 07:07
Have a nice time!
Hello, no it is not like that. It is a dynamic mesh simulation and the mesh motion has to follow this profile. So, the UDF is required I think to be used in Motion tab in the dynamic mesh setup. We do not have inlets or outlets in the simulation.
Thanks
Old   June 3, 2020, 07:16
Default Transient Profile
vinerm's Avatar
Vinerm
Whether used at inlet/outlet or for moving mesh or dynamic mesh, it is an input to Fluent. So, you can use profile. No UDF is needed. Dynamic mesh works with profile.
https://www.afs.enea.it/project/nept...ug/node398.htm
Regards,
Vinerm
Old   June 4, 2020, 07:44
Have a nice time!
Okay, thank you sir! I am gonna try to understand the method.
How to run multiple cycle pulsetile flow simulation in Ansys fluent using UDF code? Md Al Amin Sheikh Fluent UDF and Scheme Programming 4 January 28, 2020 12:55
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
Transient User Defined Function in CFX Niru CFX 0 November 12, 2013 18:07
User defined function for backflow temperature in fluent harshit Fluent UDF and Scheme Programming 2 January 29, 2013 21:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
