negative velocity between Solid zone and Fluid zone
Old   June 1, 2020, 23:06
Default negative velocity between Solid zone and Fluid zone
lili
lilistar-8216 is on a distinguished road
I'm trying to calculate heating using fluent. My calculation domain has a solid zone and a fluid zone and these zones are connected. the boundary between solid zone and fluid zone is a temperature wall, and I set UDF on it. And also I set a mass source, which is changed depending on the temperature that is defined by UDF at the boundary, at a fluid cell zone that is adjacent to this boundary. the mass source value is always positive and it means that the mass flows to fluid zone, but the axial and radial velocity around the boundary are sometimes negative especially when the calculation reaches steady.
Why the axial and radial velocity are negative between solid zone and fluid zone although mass source are positive?
lilistar-8216 is offline   Reply With Quote
Old   June 2, 2020, 10:22
Default Negative Velocity
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
A mass source should never be alone. It should always be accompanied by sources for momentum, turbulence, thermal energy, etc. since mass never comes alone. If you add only mass, then Fluent has to redistribute the available momentum or thermal energy over new mass, which could lead to negative source generation, hence, flow reversals or negative velocity.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
error, fluent, negative velocity, udf
[ANSYS Meshing] Interface between solid zone and fluid zone oozcan ANSYS Meshing & Geometry 2 August 3, 2016 12:51
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
solid to fluid heattransfer with chtMultiRegionFoam nakor OpenFOAM 11 March 21, 2011 09:28
