Finding shear rate of flow in fluent
Old   June 1, 2020, 14:52
Smile Finding shear rate of flow in fluent
Pratik Koirala
prkoirala is on a distinguished road
Hello ,
I am doing the simulation of shear rate dependent non-Newtonian fluid flow in ANSYS fluent. I am trying to find the dependency of viscosity and shear rate in this flow. Can anyone tell me how can I find the shear rate applied in wall during flow?
prkoirala is offline   Reply With Quote
Old   June 2, 2020, 10:37
Default Shear Rate
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Shear Rate is reported as Wall Shear Stress. As far as viscosity is concerned, it is a user input. However, if you want to plot, then it is available under Properties. E.g., if you go to Contours, Wall Shear Stress is available under Contours of Wall Fluxes and Viscosity is available under Contours of Properties.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 10, 2020, 11:53
Elke Jukic
elkeju is on a distinguished road
I don't really understand what you're saying. Shear rate and shear stress are two different values, especially if you have a non-newtonian fluid you can't easily conclude from WSS to shear rate.
Thanks in advance
elkeju is offline   Reply With Quote
Old   June 15, 2020, 10:27
Default Shear Rate
vinerm's Avatar
Vinerm
Yes, you are correct in saying that shear rate and shear stress are two different values. What I meant is that it is reported as shear stress not that they are same.
But then shear rate is also available, except that you have to combine the components. Velocity gradients are directly available as outcome under Derivatives.
Regards,
Vinerm
Old   September 7, 2020, 04:37
Default Shear rate of a non-Newtonian Fluid Domain (Volume)
Can Unsal
Battousai07 is on a distinguished road
Hello;
I need to monitor shear rate values in a non-Newtonian fluid volume. I am suing ANSYS CFX. Strain rate monitor has already been defined by the program however, i cannot find the proper way to monitor "Shear Rate" to the system.
Does anyone know how to do that?
Thanks in advance.
Battousai07 is offline   Reply With Quote
non newtonian power law, shear rate calculation
mass flux v mass flow rate in fluent alinik FLUENT 2 March 7, 2019 12:35
How to plot volume flow rate of inlet and outlet in fluent? RueyTeh FLUENT 5 May 12, 2017 21:37
Finding mean flow in fluent rsdsaurav FLUENT 5 December 12, 2014 05:37
mass flow rate... sanjar OpenFOAM Running, Solving & CFD 1 December 2, 2013 01:09
Target mass flow rate Saturn FLUENT 0 December 10, 2004 05:18
