ANSYS FLUENT Combustion modeling in furnace
Old   May 31, 2020, 13:27
Default ANSYS FLUENT Combustion modeling in furnace
Shubh
ShubhCFD is on a distinguished road
I want to model the flow in furnace where air fuel mixture comes from inlet burners. I have N2, CO2, CH4, C2H6, C3H8 and C4H10 as fuel composition from the burners.
I made inlet as circular on the geometry wall itself so it will act as burner.
Kindly please let me know which models I can use in this type of problem.
ShubhCFD is offline   Reply With Quote
Old   June 2, 2020, 09:22
Default Mixture
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
If it is a mixture coming in, then you can either use premixed or partially premixed model.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   December 6, 2020, 19:02
Alfin Pohan
Alfinmp is on a distinguished road
Do you have some tutorials there to do such a thing?
Alfinmp is offline   Reply With Quote
Fused Deposition Modeling Process Simulation in Ansys Fluent ttp262 FLUENT 0 October 2, 2018 17:07
ICE fluent (ANSYS): calculation is complete with combustion Mutairi_33 FLUENT 1 July 21, 2018 19:03
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
Modeling of evaporative cooling pad on ANSYS Fluent Vishnu_1991 Fluent Multiphase 0 June 5, 2014 16:17
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
