May 31, 2020, 07:45 |
compute error in report definition
kim jihyun
Rep Power: 6 |
I computed the report definition with right click, then it prints some value.
but as in the second picuture when i compute in the setup panel it prints some error message... what does the message mean? |
May 31, 2020, 08:55 |
Report Definition
This error implies missing data, such as, no-selected surface for the monitor.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 31, 2020, 11:46 |
another question...
kim jihyun
Rep Power: 6 |
thank you for the answer
the problem was in calculation setting. but here's another question. i wanna simlulate for 60seconds with 60iterations. in other word, I wanna divide 1 minute into 60 iterations. How have I gotta set the values in the picture? |
June 2, 2020, 08:52 |
Transient Simulation
The requirement of running a 60s simulation with 60 iterations is not well-defined. Iterations are what solver uses to reach a converge solution in each time-step. And time is the simulation time over which you want the system to evolve. You may or may not be able to to use 60 iterations over 60 s. That depends on the time-step that you can use and how simple the flow structure is. If you can use a time-step of 1 s then you can use NITA scheme to complete 60 s in 60 iterations. But NITA will have convergence issues if flow-structure is complex. Furthermore, use Period-Based or Frequency-Based approach if the flow is statistically steady, i.e., it has a rhythm, otherwise, use fixed approach.
Moment calculation (Hydrofoil) | YKNIPP | FLUENT | 15 | November 4, 2023 10:42 |
Specs for a compute and head nodes | rhythm | Hardware | 3 | August 14, 2020 09:55 |
execute command to create report definitions during simulations | franc1 | Fluent UDF and Scheme Programming | 10 | May 13, 2020 04:53 |
Publish REPORT from a CFD-Post macros | rubiconf | CFX | 0 | August 8, 2014 05:58 |
Report > Discrete Phase > Report > How to commands | Francesco Micchetti | FLUENT | 1 | January 23, 2008 07:10 |
