Conjugate Solid Properties
Old   May 28, 2020, 17:20
Default Conjugate Solid Properties
j
buckngnr11 is on a distinguished road
Just. want to make sure my thinking is correct here. In the solid properties, it asks to assign density, specific heat, and conductivity. The density and specific heat should only be relevant for the solid if doing an unsteady simulation, right? If I am doing a steady RANS simulation, the conductivity should be the only variable that has an effect on the solution?
buckngnr11 is offline   Reply With Quote
Old   May 29, 2020, 02:52
Moritz Kuhn
MKuhn is on a distinguished road
Yes your are right. In the formula for the thermal conduction through a wall, there is no term with density or specific heat.
MKuhn is offline   Reply With Quote
Old   May 29, 2020, 05:06
Default Steady-state Heat Conduction
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The actual energy equation is written in terms of enthalpy. For constant properties, the field becomes temperature field. However, the enthalpy and entropy are still dependent on density and specific heat. Hence, those properties are required.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Question about solid part of CHT (conjugate heat transfer) in CFX Anna Tian CFX 26 November 15, 2023 13:28
No conjugate heat transfer between solid (cast iron) and fluid (water) Rajaero Main CFD Forum 1 August 23, 2018 14:01
solid and liquid properties in solidification model Oilfish Fluent UDF and Scheme Programming 0 May 26, 2017 15:21
How to introduce solid material and its properties at wall? wassli STAR-CCM+ 3 February 22, 2017 17:01
Liquid and Solid properties in Condensation and solidification sourav Fluent UDF and Scheme Programming 1 April 2, 2013 09:13
