Calculate diffusion term from UDS transport equation |
Anne-Sophie
Rep Power: 6 ![]() |
I am looking for a way to plot the diffusion term from the UDS transport equation that is internally calculated by Fluent. Is there an easy way to do this? Since this term contains a second order gradient, I don't know how to implement it in a UDF without defining 2 extra user defined scalers. Thanks in advance for the advice! Kind regards, Anne-Sophie |
You can use SECONDARY_GRADIENT_SOURCE function to retrieve the required data. It does not return the diffusion term but the required terms for the calculation of diffusion term. It is very similar to BOUNDARY_SECONDARY_GRADIENT_SOURCE and its usage is given in UDF manual in P1 Radiation model implementation example.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Anne-Sophie
Thank you for your advice, Vinerm! I will try what you suggested. Kind regards, Anne-Sophie |
diffusion |
Species transport equation source term udf | Anshs | Main CFD Forum | 2 | May 28, 2020 11:30 |
pimpleFoam - lower nonzero limit for the production term in k transport equation | cyln | OpenFOAM Running, Solving & CFD | 1 | April 12, 2018 04:34 |
Adding a Source Term to an User Defined transport equation | rma | OpenFOAM Programming & Development | 1 | January 2, 2017 05:55 |
udf and uds for transport equation | m003020002 | Fluent UDF and Scheme Programming | 1 | September 15, 2015 01:02 |
How to add a sink term to the transport equation for the volume fraction | ASLAN_1987 | STAR-CCM+ | 2 | September 14, 2015 21:57 |
