total sensible heat transfer rate to determine convergence
Old   May 23, 2020, 04:02
Default total sensible heat transfer rate to determine convergence
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I am doing a propane combustion simulation with fluent. Actually I am trying to reproduce literature results. My maximum temperature is 100K lower than literature results.
I am wondering is this because my case is not converged yet. all the residuals in my case are flat. The monitor variable kept constant as well. Then I checked mass balance of the combustor, it's balanced. Finally I checked the total sensible heat transfer rate. The detailed data set is as follows:
inlet: -58.4W
outlet:-200W
external_wall:-182W
heat of reaction source:461.55 W
net:9.74 W
I know that the net heat transfer rate of the whole system should be 0 if the case is fully converged. However, I can not make it smaller with further iteration.
I am wondering is this an acceptable value to determine convergence or are there any ways to decrease this value further in order to get converged case.
Best regards
Weiqiang
Weiqiang Liu is offline   Reply With Quote
Old   May 23, 2020, 04:45
qin chunqiu is on a distinguished road
i would suggest a smaller one
qin chunqiu is offline   Reply With Quote
Old   May 23, 2020, 06:33
Weiqiang Liu
so it should be very close to zero in order to be converged, right?
Old   May 23, 2020, 08:54
Yes. At least 5% of the smallest heat flux among thouse boundaries.
Old   May 23, 2020, 11:31
Weiqiang Liu
Thanks very much! I'll try to further decrease the net heat transfer rate.
By the way, do you have some tragedies to aid convergece in the simulation of combustion.
I defined both my surface and volume reaction rate with UDF.
Best regards
Weiqiang
Old   May 26, 2020, 05:46
Dear Weiqiang,
I am sorry that I know nothing about combustion.
Best,
ChunQiu
Old   May 26, 2020, 09:16
Weiqiang Liu
Dear Weiqiang,
Best,
ChunQiu
thank you!
weiqiang
convergence, heat transfer rate
total heat transfer rate through wall and shadow not same preetam69 FLUENT 4 November 25, 2021 03:59
Question about heat transfer simulation convergence Anna Tian CFX 27 January 13, 2021 15:43
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Heat Transfer mechanisms tafaugl CFX 1 November 7, 2012 19:46
