May 22, 2020, 08:27 |
Turbulence Intensity in Post Processing
Rep Power: 7 |
Hi Everyone!
I need to see contours of turbulence intensity in post processing but it is not found in options. How can I see turbulence intensity? |
May 22, 2020, 09:27 |
Do you mean in CFDPost? It should be available, but if it is not you can create an expression using turbulent kinetic energy and velocity. Then, create a new variable and set it's value as the newly created expression because you can't directly plot contours using an expression.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 31, 2020, 03:56 |
Rep Power: 7 |
Thanks Vinerm, but how can I write a function for turbulence intensity?
May 31, 2020, 06:50 |
The intensity of turbulence is defined as the ratio of velocity fluctuation to the mean velocity. So, you create expression for , velocity fluctuation, and then divide it by velocity magnitude. Look at the following
https://www.cfd-online.com/Wiki/Turbulence_intensity
Utilities: post average turbulence fields and create turbulence fields for LES | Hanzo | OpenFOAM Running, Solving & CFD | 10 | August 18, 2017 19:33 |
Turbulence Intensity vs Reynolds number | jason580315 | ANSYS | 3 | March 1, 2017 06:21 |
Question on Turbulence Intensity | Eric | FLUENT | 1 | March 7, 2012 05:30 |
How to define the turbulence intensity and mixing length at an outlet (for k-eps)? | david39 | OpenFOAM Running, Solving & CFD | 6 | February 2, 2011 04:01 |
High Turbulence Intensity Problem | bwg | FLUENT | 1 | January 13, 2010 14:09 |
