3D cylinder with baffles (solid no tube) - Calculating Pressure Drop
Old   May 20, 2020, 08:23
Default 3D cylinder with baffles (solid no tube) - Calculating Pressure Drop
Bola
Famous is on a distinguished road
Hey Everyone,
So I am trying to make an exhaust heat recovery system using fluent.. I am trying to analytically calculate the pressure drop to compare it with the results from fluent. I've been searching for weeks however i always get pressure drop calculations with tubes through the baffles however for my case this isnt the issue.
So i was wondering how do i analytically calculate pressure drop for a 3D cylinder with N number of baffle with no tubes and is purely a solid.
The equation would be more beneficial as i will creating multiple scenarios.
Given
Mass flow rate: 0.05kg/s
Ideal Gas
diameter of inlet: 9cm
Length of cylinder: 30cm
inlet temperature of: 752.5K
pressure outlet 0 guage
baffle thickness = 0.5cm
baffle cut: 50%
baffle spacing :4cm
I have also attached a picture
Thank you soo much for your help.
Famous is offline   Reply With Quote
Old   May 20, 2020, 16:02
Default Analytical Solution
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
It appears that you are expecting help in analytical approach and not numerical approach. Is that correct?
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 20, 2020, 17:43
Post
Bola
Yes the analytical approach
Old   May 21, 2020, 07:58
Default A million dollar problem
vinerm's Avatar
Vinerm
Well, the problem has no analytical solution. There is a million dollar prize, called Millennium prize, for just proving that such a solution exists and is unique. You can either solve it numerically, using CFD, but I suppose you have already done that or using lumped parameter models, such as, by dividing it into various zones. I suppose you are looking for empirical correlations and not for analytical solution. If you search with correct terms, you might find some approximation.
Regards,
Vinerm
Pressure fields in FOAM, p field, total pressure, etc. Tobi OpenFOAM Post-Processing 9 March 25, 2022 02:33
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
OpenFOAM - cyclicAMI Pressure drop result variation Vishsel OpenFOAM 0 May 31, 2019 03:47
Pressure Drop mumtaz ersan Main CFD Forum 3 April 23, 2015 10:20
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
