Torque is increasing with respect to the TSR never decreases |
May 20, 2020, 06:41 |
Hüseyin Can Sülük
Rep Power: 6 |
Hello guys i am trying to simulate a Savonius wind turbine with sliding mesh technique and k-epsilon realizable. Wind turbine placed at 0,0,0 where its shaft is on the y axis i am calculating it is torque as =torque_y()@blade (i have created named selection blade as wind tubine) then i am creating expression as torque with this function and get transient chart
1- With this values coming from chart should i take absolute value of them because many time torque values cross - part of graph. 2-Torque is always increasing with increasing TSR i mean theoratically at some point it should start to decrease i have tried different meshes but results is same what should i change ? |
May 21, 2020, 19:10 |
Hüseyin Can Sülük
Rep Power: 6 |
I have solved negative torque problem but still my torque value is too low torque coef. is around 0.085601721 and still have problem with 2 question torque always increasing with respect to TSR
May 23, 2020, 07:38 |
Hüseyin Can Sülük
Rep Power: 6 |
I have added moment and residuals graphs i think they are ok but still i get really low torque values or i am mistaken my savonius wind turbine has H=0,2 m D=0,204m and inlet velocity is 10 m/s which makes possible torque around 0.254898 but i am getting my torque value is around 0.035 i really need help guys i am stuck at this point
May 26, 2020, 09:32 |
Torque
For a rotating system, you need to resolve the boundary layer, i.e., . And is preferable. Turbulence model will not make such a significant effect but wall treatment will. Furthermore, ensure that you have selected all the relevant walls responsible for generating torque.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 7, 2021, 22:19 |
Aryo Yuwono Hasbi
I get the same problem with Mr. Huseyin 2nd question. I've tried to use different model turbulence (i'm using SST on the first time, then changed it to k-w, standard k-epsilon, and RNG k-epsilon) but it keep makes the same pattern in TSR x Cp graph. The torque didn't reach the peak point and keep increased along with increase of TSR. I'm trying to simulating it in TSR 0,6-0,9. My Cp in TSR 0,8 is good (almost as same as experimental research with error 1,7%), but on the other TSR, it's not that good (the error is above 20%). Anyone can help us with this problem? (anyway, i'm using cfx)
VAWT - average torque = 0, and TSR very low for 1dof system | toftegaard23 | FLUENT | 3 | August 11, 2024 21:36 |
How do I calculate power coefficient with respect to TSR of savonius VAWT ? | ahmedna8 | FLUENT | 2 | October 4, 2022 18:17 |
Propeller Thrust and Torque Increasing | KindaHungry | STAR-CCM+ | 1 | November 3, 2018 05:59 |
Cp is increasing with increase in TSR and never decrease in 2D Unsteady analysis | HUSSAIN MAZARBHUIYA | FLUENT | 3 | February 12, 2018 11:31 |
Increasing RAM decreases CPU time!!! | Melih GULEREN | FLUENT | 2 | April 5, 2004 06:21 |
