How can I explain the cd and cl theoretically?
Old   May 19, 2020, 13:17
Default How can I explain the cd and cl theoretically?
alvaro varela
Varoesp98 is on a distinguished road
Hello, I would need that someone send or recommend me somewhere to look for information about how the lift coefficient and the drag coefficient affect in the flaps and slats of an airfoil. The idea is to see the difference between the cl and cd for an airfoil without slats and flaps, and the same airfoil but with slats and flaps. I have already gotten both cd and cl for both of the cases but to make it in a proper way I need some theory to explain it, with formulas and as many things as possible. Please if you can help me I would be very glad because I could not find anything through the internet.
Varoesp98 is offline   Reply With Quote
Old   May 19, 2020, 16:29
Default Clarity
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
I am sorry, but your description is not clear. Drag and lift coefficients are just non-dimensionalized forces acting on the solid object along and normal to the flow. So, the explanation is rather simple. Reduction implies reduction in force and increase implies increase. However, to compare the cases, you have to maintain same non-dimensionalization parameter, i.e., same dynamic force should be used despite differences in geometry.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 19, 2020, 16:43
alvaro varela
Hello vinerm, what I mean is that I need to read and learn, how those forces are acting when I add flaps or slats to an airfoil, there should be some theory about how they act towards an airfoil, that is what I need, to read and learn about it.
Old   May 20, 2020, 06:54
Default Forces
vinerm's Avatar
Vinerm
The forces act independently of the geometry. However, their distribution change as the geometric changes are made. But a force is a force. It pushes and rotates about the center of pressure, provided CP is not same as CG.
Regards,
Vinerm
Old   May 20, 2020, 07:19
alvaro varela
okey thanks
