energy under relaxation factor in combustion simulation
Old   May 19, 2020, 08:17
Default energy under relaxation factor in combustion simulation
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
Recently, I am doing a propane catalytic combustion simulation with fluent. I set the under relaxation factor of energy to 0.7 at beginning of iteration.
the maximum temperature of combustion kept increasing with iteration. In order to accelerate iteration, I set under relaxation factor of energy to 0.95, then the maximum temperature kept decreasing until to room temperature.
I wonder how would under relaxation factor of energy effect combustion results. How should I determine convergence in this case?
Best regards
Weiqiang
Weiqiang Liu is offline   Reply With Quote
combustion, convergence, energy, under relaxation
Long output in terminal. ssa_cfd OpenFOAM Running, Solving & CFD 1 March 18, 2019 06:25
Simulation data was exchanged between the two models souza.emer Fluent Multiphase 0 February 11, 2019 09:48
Combustion Chamber Simulation ms91 STAR-CCM+ 3 September 12, 2018 10:37
Doubts Regarding Performing Combustion Simulation in OpenFoam DineshMyilsamy OpenFOAM Pre-Processing 0 June 26, 2018 08:39
Diesel combustion simulation ( Heat release rate) venkatesh Siemens 2 April 29, 2009 08:38
