Post-processing: Diff between reports for Total Heat Transfer Rates |
May 19, 2020, 07:22 |
Annon
Rep Power: 16 |
While performing a heat transfer analysis simulation (2D, transient, coupled heat transfer model), I recorded the heat transfer across boundaries by setting up: Solution->Report Definitions->Flux Reports-> Total Heat Transfer Rate -> Per zone flux (selecting all the walls). See the attached image - A. At the end of the simulations I calculated the fluxes independently by: Results->Reports->Fluxes->Total Heat Transfer Rate (selecting all wall boundaries). See attached image B. However, the heat transfer rates I obtained were different from the above method. Why is this? Which is the correct method? Thanks, |
Evaporation-Condensation in a porous zone (Heat transfer problem) | maximilian-1 | Fluent Multiphase | 1 | August 22, 2018 10:42 |
Heat transfer coefficient in regenerator | gartz89 | FLUENT | 0 | May 26, 2018 02:23 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 12:59 |
Post processing for heat transfer coefficient | veebs | CFX | 0 | August 3, 2001 05:27 |
