Modify UDM name
Old   May 16, 2020, 14:06
Default Modify UDM name
Pedro M Balsalobre
pedromarti95 is on a distinguished road
I am trying to set the name of my user defined memory to visualize it in postprocessing, i am using Set_User_Memory_Name function, but i always obtain the error: function "Set_User_Memory_Name" not found (pc=299).
I tried adding sg_udms.h, udm.h and sg.h libraries, but is the same.
My code is something like:
C_UDMI(cell,thread,0) = q;
Set_User_Memory_Name(0,"pop");
I also tried the Set_User_Memory_Name function in a DEFINEONDEMAND udf, but i have the same results.
Thanks if you can help,
Regards.
PMB
pedromarti95 is offline   Reply With Quote
Old   May 16, 2020, 17:13
Default UDM name
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Are you interpreting the code or compiling it?
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 16, 2020, 17:35
Pedro M Balsalobre
i am interpreting the code, should i compile it?
Old   May 18, 2020, 04:05
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I recommend to put the line you are using in DEFINE_EXECUTE_ON_LOADING macro
DEFINE_EXECUTE_ON_LOADING(any_name_here, libname)
compile UDF
sometimes you should reload compiled library to make changes in UDM names
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   May 18, 2020, 05:25
Default Compilation
vinerm's Avatar
Vinerm
Setting of UDM or UDS names and units require compilation. And also note that names can be set only once. If you want to change names, you have to close Fluent session and start a new one.
Regards,
Vinerm
set_user_memory_name, udm
Segmentation violation louiza FLUENT 16 June 27, 2017 16:41
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 10:01
Udm nasser FLUENT 0 April 7, 2013 10:19
