May 15, 2020, 17:40 |
fluent error
Rep Power: 6 |
Dot product of flow direction and area normal is zero.
Check the specified flow direction on Mass Flow Inlet boundary conditions for thread 9. I've just start the simulation, but suddenly this sign pop up. What should I do? thank you |
May 16, 2020, 06:05 |
Lucky
Rep Power: 66 |
The instructions are clear... check your settings for your mass flow BC.
fluent, running error |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 05:53 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
