define "yplus" in custom field function in fluent
Like Tree6Likes
Old   June 2, 2020, 11:14
Default Mesh
  #21
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The mesh looks good though you have some jumps in the size, but it should not be a problem since the jumps are not large.
Mutlaq likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 2, 2020, 12:49
Ali Suleiman
Mutlaq is on a distinguished road
I'm really grateful to you.
Mutlaq is offline   Reply With Quote
Old   June 5, 2020, 17:15
Ali Suleiman
Mr. vinerm How can I check my results if the results of all research are related to y+? I try to calculate y+ but that very difficult in fluent
Old   June 6, 2020, 08:58
Default Wall Yplus
  #24
vinerm's Avatar
Vinerm
You don't need to calculate y^+; it is already available as Wall Yplus under Turbulence. However, it is not available if the flow is laminar.
Mutlaq likes this.
Regards,
Vinerm
Old   June 6, 2020, 09:26
Ali Suleiman
it is available for a first layer only not exceed 2 or 1 is related with the value of y+ that I put of mesh only for first layer, not all layers
Old   June 6, 2020, 11:35
Default Yplus
  #26
vinerm's Avatar
Vinerm
y^+ has significance only for the first layer. What you are talking about is not y^+ from one case but from different cases with different y^+ values.
Mutlaq likes this.
Regards,
Vinerm
Old   June 6, 2020, 11:40
Ali Suleiman
so they merge the results of all of the mesh test. did you mean that?
Old   June 6, 2020, 12:04
Default Graph
  #28
vinerm's Avatar
Vinerm
No one does it that way. The results are usually based on theory or experiments. Using CFD, no one plots results against y^+; it does not make sense because that is the input to CFD and not its output.
Regards,
Vinerm
Old   June 6, 2020, 12:07
Ali Suleiman
so how I can validate the results with other research paper if almost of paper results with either velocity friction or with y+
Old   June 6, 2020, 13:55
Ali Suleiman
Many research papers have similar results to the picture
Old   June 6, 2020, 16:58
Default Dns
  #31
vinerm's Avatar
Vinerm
Those are based on DNS (and LES), both being scale resolving simulations, though LES also requires wall modeling. In those cases, at least in DNS, all the scales are resolved and no modeling is required. That means, the results are same as those from experiments. The meshes are extremely fine and usually NOT solved in time domain, but in frequency domain. Nonetheless, the profile requires shear stress availability at different distances from wall. You can also do that, but if you are using a wall function, then it does not make sense. It would be akin to entering a profile and then plotting it to show it as an outcome, which it is not. If you are resolving the boundary layer, then you can determine wall shear stress using different values of wall distance and plot this graph. Refer the following
https://ansyshelp.ansys.com/account/..._th_stdwf.html
Mutlaq likes this.
Regards,
Vinerm
Old   June 8, 2020, 17:52
Ali Suleiman
Mr. vinerm I ploted the urms/ut Vs y+ but I don't why the plot appears like this, did you have any idea?
Old   August 2, 2020, 11:30
Ali Suleiman
Hi, Mr. vinerm how are you?
can I ask you how can i find Ave Nusselt number???
Old   July 29, 2022, 08:25
Ali Suleiman
[QUOTE=vinerm;773044]The mesh looks good though you have some jumps in the size, but it should not be a problem since the jumps are not large.[/QUOTE
Hi Mr. Vinerm I would asked you about how can add hardness to CFX ANSYS I CANT FIND IT
IF YOU HAVE IDEA HELP ME PLZ]
#fluent #cff
Fluent Custom Field function saidkhaled FLUENT 2 March 30, 2020 07:16
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
Force Report help~ or maybe Custom Field Function sailor FLUENT 0 April 13, 2011 04:45
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
